Projects & Parts => Garage/Tech => Topic started by: Jthomas on March 14, 2015, 01:44:51 AM
Title: 10 bolt front axle vs. world
Post by: Jthomas on March 14, 2015, 01:44:51 AM
these axles are give aways. I understand that there are far superior front ends out there.
If I put a good set of joints in it, and bigger shafts, would it be able to hold its own against a 35-36" tire?
Seems the only time I broke them in stock form, was on 35s and wheel hop when pulling someone out
I really don't use 4x4 that much, so I wasn't sure if I should follow suit and swap a 60 in it. Orrrr?
Corp 10bolt 8 lug
Title: Re: 10 bolt front axle vs. world
Post by: ProGrade on March 14, 2015, 02:23:39 AM
I ran corp 10 bolt 6 lug with 35's with no problem.  Just be smart,  like don't hammer down with the wheel cranked.  Common sense will keep you having fun.
Post by: Jthomas on March 14, 2015, 02:43:19 AM
Would a 4340 28 spline be as tough or tougher than a 1541 30 spline?
Post by: marshall on March 14, 2015, 04:14:13 AM
Bigger shafts are a waste of money, run it like it is.
Post by: Jthomas on March 14, 2015, 02:28:34 PM
What about a locker or spool?
Post by: Boggen Joe on March 14, 2015, 02:48:25 PM
No on locked front end 10 bolt. It won't rake it. I ran 42s with a 10 bolt front and only broke 2 shafts in 1 year.
Post by: Jthomas on March 14, 2015, 03:02:03 PM
I figured as much. The vehicle it's going in isnt a mud bogger, so I don't know if that increases its life span or not lol
Joe, is it the shafts you are breaking, or is it the joints?
Everytime I broke them, it was the Ujoint strap. I haven't ever sheared a shaft. So I can't tell if it's the joint that breaks, and tears the straps up, or if the straps are breaking, and the joint breaks during the carnage.
Post by: Jthomas on March 14, 2015, 03:04:10 PM
Maybe just a Ujoint upgrade could help me out?
Post by: 84silverado on March 14, 2015, 03:59:30 PM
when the bogger was smaller i had a 10 bolt 6 lug with stock 3.08 gear up front with a yukon locker, i ran RVT 36.5 tires that looked almost like ground hawgs. i jumped it, left it under water for a few nights, drove it to work, school, everywhere and beat the p00 out of it relentlessly. i only ever replaced the passenger wheel bearing once, checked the fluid every now and then and greased it. run it and dont worry.
Post by: 4x4xdodgeman on March 14, 2015, 05:00:52 PM
its not the ujoint breaking. its not enough metal around the joint.
Post by: Wild One on March 14, 2015, 06:43:34 PM
I have 10 bolt shafts in my front
Run 44 Swampers hard!!!!
Recommend spicer joints!!
Post by: Jthomas on March 14, 2015, 06:59:30 PM
What about a 4.56-4.88 gear?
Post by: ProGrade on March 15, 2015, 01:27:42 AM
If the ujoint seizes up it will tear the straps up.  Put good, greasable joints in and take care of them.
