Projects & Parts => Garage/Tech => Topic started by: hillbillydeluxe007 on March 23, 2015, 02:50:30 PM
Title: 454 vortec need help
Post by: hillbillydeluxe007 on March 23, 2015, 02:50:30 PM
My tach will fall first then the truck dies then it will start and die again the timing is good so it's not the gear on the distributor iv never had a truck do this it's getting fuel cuz if I keep trying to start it it foolds out and smells like gas, so my tach drop and I loose spark any ideas ???? Thanks
Title: Re: 454 vortec need help
Post by: dirtydog on March 23, 2015, 07:23:36 PM
check wires to coil a believe a buddies vortec 5.7 did that then wouldn't start n found broke wire by coil. just idear.
Post by: Swampthing on March 24, 2015, 12:51:04 PM
un hook the tach. I have seen them short out and shut the engine off.
Post by: hillbillydeluxe007 on March 24, 2015, 02:42:56 PM
No broken wires and ill try the tach when I get home it i think it needs the tach to run don't it ???
Post by: 72 Bogger on March 26, 2015, 03:54:10 AM
It was my truck that the tac was f%#@g up on... but it wasnt making my truck die... just made the tac jump and quit working all together one day.. i found the broken wire when it wouldnt start one day.. it ended up being my cap and rotor went bad again.. those style are a bad design..but yours sounds like a short someplace..
