sargent slaughter 2.5 ton gmc's
Started by cnoswalt78, September 28, 2010, 03:36:14 AM
Quote from: cnoswalt78 on March 18, 2011, 05:43:46 AM
oh man have you guys seen a cammed 454 dually smokem and its posi, wow itll lay 20-to-40 feet with out effort ha its cool, headers 3'' duals with crossover and flowmasters sounds mean, and iv got guys with power strokes always trying to race me, ha and haul the hole family to. but wiring is all screwed up gotta fix it more. ill get pics on here soon.  Im thinking or sargent slaughter logo on it so itll go with the truck. would that be cool or dumb?
ya arnt gunna be able to haul much with it if ya burn the tires and tranny out  screwin around  J M O
oh ya my old 74 dually would smoke em half way thru 2 nd gear  i learned real quick how expensive tires were  then carrier bearings then u joints then trans and flywheels   wrecked a real nice truck    now i need a tow rig
cnoswalt78
#63
Ok sargent slaughter has new paint, an exact copy, going to rip off the drum brakes , when i get a chance. currently starting on the wheels. then brakes, exhaust, thinking 3.5'' down flow no muffs 4 feet long, or will it be to loud. also got 3'' in 2-3''out modded flowmasters that would work.
Im just wanting the exhaust to blow throu the mud, that looks cool!
also thinking headers going out the fenders and up,(it would have to be easly removeable) so i can install the muff exhaust
poorboyzmuddin
IT IS WHAT IT IS.......
cnoswalt78
how wide can a 1600x20 tire fit (how wide a wheel) ?
I would try to look it up but cant find any info on this.
tire shops say min 10" but ive seen them on 8" wheels, tire shop says 12 to 14'' wheel is best but what about wider?
is there any problem with to wide? like 16'' wide or 18'' wide?
OK...... IDEA..... why cant i take 2 wheels and bolt them together  with the lugs as a split rim and forget the lock ring a simple 2''wide chunk of 20'' pipe to fill the gap and presto easy to dismount wheel? BUT WOULD IT WORK?
cnoswalt78
ummmmmmm, will it work or dont understand?
