Motor Question
Started by SteveP612, August 04, 2008, 04:51:25 PM
SteveP612
I have a question about a motor.  I pick up a 350 for free.  Pretty much just the block, crank and pistons.  It was stored in a plastic back for at least 11 years with the heads off the person told me.  The cylinders are rust a little bit no pitting or anything.  I can rub the rust off with my hand.  Problem is the pistion are set up from sitting.  Is there anything I can do to free them up or is this motor junk.  I am in no hurry and plan on boring it out and use for a spare.  Any suggestions on this would be appreicated.
1997 Jeep Cherokee and 91 YJ
Bo Duke
Yeah, pour some ATF in all of the cylinders.... or break fluid, one of those should break it loose.
SteveP612
Thanks guys.  Ill try the PB Blaster first
Ghetto Fab
PB blaster is a godsend  i use it all the time
