broken XBOX360 i need help
Started by johnolia, February 14, 2009, 04:14:56 AM
johnolia
does anyone know how to fix a xbox360 mine has the RROD crap thanks in advance
1992 f150 302 with flowmaster 40 series
Are 3 red lights lit up or is all 4 lit up?
Ring of death? It's done. My sons went to p00 Christmas night. He got 5 new games and couldn't play them so I bought him a new one with an extended warrenty from Game Stop. I got $80 credit for the old one. This happens alot with older units. The newer ones they say are better, I guess they fixed the problem the older ones were having.
chetney
#4
Quote from: Disturban on February 14, 2009, 06:16:43 AM
Some have confused General Hardware Failure with a similar looking error warning where four red lights appear, in which case the console does not detect an AV cable is plugged in. The four lights can sometimes also be seen when power surges or very brief power outages occur while the console is running, in which the console needs to be unplugged and plugged back in again to reset the error.
The RROD is 3 lights it does not make a complete ring. 3 red lights is bad 4 is good (Complete RING)...just need to reset something.
chevyman350
not recommended but wrap it in a blanket and let it run itl overheat and shut off which resets itself it worked for mine but prolly not the best choice
frdboy86
on the original ones they put the processor too close to the power supply and it melts the solder on a couple connections.   One of my friends actually did the overheat thing but it ended up going bad again like a week later.  Your choice......im not saying yes or no on that.
Send it in to get fixed  but by that time the money you spend in shipping and repair costs you might be better off finding another used one at one of the game stores or cheap used by someone else.
Norm Henderson
did you try to kick it......that might work
Drive It Like You Stole It
johnolia
its three red lights and it is a hdmi unit which means it was made in the late 07 to the early 08 year so its still farely new no one is safe xbox has a 30% failure rate and thats just the the people who complained...looks like ill just have to buy the repair kit and do it myself
Disturbed Sledneck
JeepXJ98
haha look on craigs list.. there is a lot of people/shops that can fix it for like 20 bucks.. I have a modded 360 and so does my friend, when he RROD he took it to some dude and its worked perfectly ever sence.. some time its just as simple as the soder from the mother board to the video card gets too hot and melts.
IOMO
he got a repair kit off ebay to fix the solder on the one card.. i guess he didnt want to kick it? lol
Send it back with an estimate from Radio Shack for a PS 2
ask them to repair and return on their dime.. or else!!
theBroken
#15
OK first off nothing inside there gets hot enough to melt any solider. What it is is theres not enough space under the X clamps that hold on the CPU and GPU so the heat dont dissipate. What you can do is take it all apart and get some washers to replace the X clamps off the mobo. I would also recommend going to llamas website and getting a better quieter fan. Very easy to install. I you need to know how to get the case off the 360 look on you tube. Your first time taking it apart is a PITA but after you do it once it comes apart real easy.
llama can explain it better than I can
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
New fans
http://secure.llamma.com/catalog/advanced_search_result.php?keywords=core&x=0&y=0
Another thing is GONT LEAVE IT ON ALL THE TIME.  Thats is what kills them.  Also get the extrenal cooling fan set up. It helps alot if its in a enclosed space or sitting on carpet or any thign that does not let it get cool air to it
I have mine sitting up right on a desk all by its self and i never leave it running if I am not playing with it.
johnolia
i never left it running when i wasnt playing it.
and it already had the washers on it when i got it found that out after i bought the kit and took it apart....
but still had rrod.
the problem was that for microsoft to fit a dvd drive in the xbox they had to make the gpu heat seank smaller ALOT smaller so yeah its a design flaw and the repair kit is already in it and its still broken anyone wanna buy it ill take $60 for the councle and the wires thats the going rate for a rrod xbox on ebay
theBroken
Quote from: samolia on February 23, 2009, 06:50:06 PM
but still had rrod.
Do the RROD come on rite when you turn it on or after a few minutes?
johnolia
Quote from: theBroken on February 23, 2009, 09:32:25 PM
but still had rrod.
right when i power it on
