engine block fix???? and got a question about the head?
Started by rebelryder, March 26, 2009, 12:54:17 PM
rebelryder
so i have a 4.0 that the rod busted a hole in the block. was wondering if that is repairable or not. i doubt it but i figured i would ask
i can just get the tip of my pinky in it its really not that big of a hole.
also i got my old head dirty when i was tearing it out. i need to put it on the new engine now since it has a burnt valve and a bad bad tick. can i just use a garden hose or should i use mineral spirits
ufwda.org
would make a good boat anchor
rebelryder
thanks BD leave it up to you to leave a smart comment  ;D ;D loll loll ==roll
ufwda.org
NOPE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
4.3's are a dime a dozen just get another one and call it a day.
rebelryder
thats what i figured. you musta fat fingered it today also hahahahaha its a 4.0 ==lol
ufwda.org
Kodiak450r
personally i'd get a new block. if your short on cash you can JB weld that hole shut using some window screening as a backing to stiffen it up. not alot of heat in that area and jb weld is pretty oil resistant if done right. the block must be perfectly clean though so a good hot tank session would do.
i wouldnt waste yer time trying to fix that hole...  i have a 4.0 ill practically give ya, prettymuch complete too
rebelryder
well i was just gonna rebuild this one so i can have a spare engine. how much ya want for the 4.0 eroq?
ufwda.org
Quote from: Kodiak450r on March 26, 2009, 02:38:01 PM
OK, you were on the right track with the new block part.... then it all went down hill with the JB weld part.  That is just a ridiculous thing to recommend.
the harvester
i would not recommend jb weld but have seen many blocks jb welded and most of them held up well
Kodiak450r
Quote from: the harvester on March 27, 2009, 08:22:46 PM
x2. i have a block thats in my S-10 JB welded in the valley due to a crack that coolant was leaking internally. and thats in a hot area with 15 PSI of coolant pressure against it. no problems with over 5000 miles on it since build.
I guess I am just not one to take short cuts on things like this.
If I am going to do a fix that concerns the block... I am going to fix it right the first time.  Everything else bolts to the block.  The quick fix doesnt hold... off everything comes.
Now, maybe an intake I would consider.
rebelryder
now what about cleaning the cylinder head. i got dirt on it when i was tearing the old engine out and i need to change the head on the new one with my old head. should i just use water or mineral spirits
ufwda.org
Kodiak450r
depends what kind of dirt? dirt from the ground or engine grease and grit? soap and water will take care of the regular dirt mineral spirits will take care of grease and grit. might have to do alittle scrubbing with a wire brush.
rebelryder
just dirt from the ground and from the engine bay and what not. i think i may just take some mineral spirits and dunk it in a bucket.
ufwda.org
