oil in the top end?
Started by Hitman89x, January 28, 2011, 01:03:29 AM
Clevite is a good brand, and the stuck ring would def cause all the trouble. If you dont have a micrometer set, you should take your pistons in to a machine shop and have them measured to see if theyre collapsed or otherwise turned to p00 from the overheating deal. You cant eyeball this stuff, it has to be measured. Replace all the rings, check your bearings. The damage might not be limited to just 1 piston. Do it right, tear it down all the way and check it all out real good. ;D
yeah man defenatly check the other pistons, and get that one replaced or get your money back, that's def a man defect!!
Hitman89x
yeah the company has not email me back yet i emailed them last week!!!!!!!!! gunna try again cause that is BS for the money i dished out and cant even get a response!
