trans questions
Started by michigan maniac, January 30, 2011, 08:06:03 PM
im looking to go to a divorced tcase set up on my 85 chevy, im leaning towards using a 2wd turbo 400,  was wondering about manual valve bodies...anyone run one in there truck...?
whats everyone else running for a divoreced setup? any pointers?
chevystudz7105
im not runnin a divorced case  or a 400  but i have a reverse shift pattern manual valve body in my 350 trans and love it.   only thing i would change about it is going with the other valve body tci had  rather then this one  cuz i hate the engine breaking system it has.   dont know why i bought this one in the first place.
if i remember right  manual valve bodies for  400s are expensive.  i believe 400+.  i could be wrong or maybe prices came down but when i was lookin for mine i ran across alot for 400s  and everyone was over 400
Use a manual valve body on a th400.  They are known for blow shifting.  I have a 2wd th400 if you need one.  PM me.
Quote from: ChevyRacer1981 on January 31, 2011, 01:16:14 AM
what is blow shifting? and how much for the th400? what condition is it in?
is this gonna be in a dd? if so you might get sick of always clicking the shifter up and down all day long. you might want to look into a manual/auto vale body swap.
Quote from: michigan maniac on January 31, 2011, 07:55:33 PM
Blow shifting is when the trans will shift into 2nd when you have it all the way down into 1st.  PM sent.
Quote from: KORNBREAD on January 31, 2011, 09:49:14 PM
no its for my bogger
Quote from: ChevyRacer1981 on January 31, 2011, 10:09:09 PM
thanks for the info!!
