fuel pump?
Started by Mudduck, February 22, 2011, 10:23:26 PM
Mudduck
I m working in this it a tbi motor chevy truck  it will turn over easily but wouldnt fire immediately i had to pump the gas.pedal like a carb. And try to start it up  once it start up i have to keep press the gas pedal just enough to keep it running otherwise it ll die was thinking fuel pump is ready to go?
Mudduck
==hstrap
Check the codes first before you buy anything.. It does sound like a fuel pump, can you spray somethin in the throttle body and see if it runs better? Be careful, dont try it if its backfiring or anything like that..  ;D
Check fuel filter first...those pumps run at such a low psi it most likely to run right or not run at all if there is a problem with the pump. From what you describe though my first suspicion would be IAC valve.
