low gear or high gear???
Started by Mudduck, August 07, 2008, 03:25:03 AM
WhiteTrashDRC
i run low almost all the time, till i break a u joint strap that is
dodgee, ==dew
bigmud44
150feet low over 150 feet high .keeps engine in its power band ;D
Boggerram87
Low...I Need All The Gear I Can Get
mutt truck
I have always tan low loc, but on the 19 th at delaney bog i threw it in high and it seemed to work just fine for me with my 455 and 4.88 gears so i guess i will see what it does in warmer weather.
tonkatruckon44s
i use low when crawling or climbing and rarely actually use high its either 2 wheel or 4 low unless im just on terrain im unsure about then i use 4 hi
In my CJ I was 4 low.  I crawled threw everything. and I didnt have to give it much gas to do it.
The Wagoneer is High. Can get it to go into 4 Low with the Linkage and vacuum line broke.
Boggen Joe
MidMichiganMudRun
It all depends on the event or the mud.. Most of the time even with 5.87 gears i run in low lock... Just seems to work better when i get into deep mud
Quote from: BIG DOG on June 18, 2010, 02:36:57 AM
==sick ==sick ==doh quiett             didn't your momma tell you, if you didnt have something nice to say    shut the hell up then  ha ha ==jk ==jk
   low lock big block     sounds like a cough drop   even orange in color   i;m thinkin
gotta love them  Mills folk, lol    picked up some Orange popsicles for ya Clyde,lol
broncoron
high. never lets me down. low is for pullin people out.
fordboy19
Low lot more torque n tire speed
cnoswalt78
gotta do low iv got 6.17 gears
MrCompton734
Well I try to always use 4-hi. 4-low with 3.55 on 32s is just.....well it's too much lol even with the little 5.2 in my 97 Ram.
Dad, I'm twelve.
For all the people that say that low range is to  much.....you mean it is at redline in low range in 3rd or Drive (depends on tranny) ?????
LOW LOCK AND BIG BLOCK !
nothing else to say ;D
4 hi usually.... old motor, i try to keep the bottom end in tact. seems to do better in it anyways. 4 low is only when i gotta do a slow pull on a hard surface
thinking high rangein the new jeep way more wheel speed to stay on top with.       low is great for wickin it.      heavy trucks with big tires use low and save the trans
monsteram
vie got a 208transfer case with schmitty internals  9:1 ratio so i have to run 4 hi
ed_ley1980
I have to run low i only have 4:10 gears with 42 and a half inch tractor tires and a stock for 460 the 205 transfer case doesnt help either i need a 208 that would help some
