no compression in one cyl and its leaking out the intake valves
Started by Crazymays77, July 02, 2011, 08:19:43 PM
Im guessin theres no way to adjust the valves on this? If thats the case then you have to check the installed height of the valve which is the distance from the part of the spring that is in contact with the head to the tip of the valve. On these non-adjustable heads the installed height is critical, if its too high the valve will be held open or will open early, causing the problem youve described. If the installed height is too high, simply grind the tip of the valve off until it is the correct measurement.
yup there not adjustable. well i changed a few of the lifters out on the intake side. got cyl 2 to work but now 3 and 4 dont. wtf. so now i have to change out the lifters on 3 and 4. guess i should have left them alone. lesson learned. just dont feel like messing with it right now. going to take a nap and work on it later today or mow lawn. at least i found the problem and i dont have to pull the head off.
