panhard bar
Started by prostock2414, September 06, 2011, 12:57:22 AM
prostock2414
well for some reson I seem to think this will work and alot of people on here seem to not think it will opinion's? Tips on a way I could set it up I onl put it on there becasue the truck has sooo much body lean when you turn it did help but some people seem to think it will bend and break my suspention?
you need a sway bar.... take that off and make a sway bar
By what I have read. U shouldn't need it since u r 4 linked. I don't have one on my 4 link in the rear but I do in the front since it's only a 3 link. But idk
prostock2414
Quote from: Crazymays77 on September 06, 2011, 01:00:05 AM
yeah I put it on there in a burst of anger lol and Idk I guess Ill cut it off and go from there just a big waist of money
rangerwheelinmike
cut that off and make a sway bar!
prostock2414
Quote from: rangerwheelinmike on September 06, 2011, 01:01:49 AM
Im guna lol need some oxygen for my torch
prostock2414
Now should I mount that on the front or no way?
rangerwheelinmike
no not if you havea  4link
prostock2414
Quote from: rangerwheelinmike on September 06, 2011, 01:05:12 AM
sum bi**h I wasted some money on them stupid bar's :(((((((((((((((
557stroker
u need sway bar front and rear
prostock2414
prostock2414
http://bigshocks.com/photo4.1.jpg
that's what im makein guna cut the old stuff off tommoro complete waste of money noob mistake but learned from it so ill take it for what it's for lmao hopefully this end's all this ;D
A pan hard bar just helps keep the axle from moving side to side, if ur 4 link bars run parallel u will need the pan hard bar but since your top bars angle down and narrow to the top of center of ur axles this will keep the axle from moving therefore eliminating the need for the pan hard bar, the only way to get rid of body sway is the sway bar as u have already heard from everyone on here, and a sway bar is needed on both ends but because not to make you sway bars to week or strong because this will effect the ride of your truck
prostock2414
Quote from: erikmud on September 11, 2011, 02:47:57 PM
This is very true . I cut the stuff off im makeing sway bar's just need to fab everything up should work out great thanks guy's
