heads and compression
Started by 76 chevy shaker, September 21, 2011, 02:34:56 AM
76 chevy shaker
will 882, 76 cc heads sustain 10.83:1 compression?? or do i need a new set of heads??
thanks for any input.
no they won't they'll get you in the 8's depending on the bore, stroke and piston you have
76 chevy shaker
ive got kb dome top 2 valve reliefs claimers .060 over bore 5.7 rods
76 chevy shaker
standard stroke at 3.48 and dome cc -14
do you know your deck height, or what head gasket your using?
76 chevy shaker
felpro head gaskets compressed .041 deck clearance .045 is there a chat on here?? cause its easier to communicate. im a newb.
yeah there's a btab at the top that says chat...
if that's all accurate then your static ratio is 10.19 to 1
Deck the block, angle-mill the heads, pop-up pistons, gets you about 10.5 or so maybe pretty close - itll sure enough wake that motor up and youll need better gas  ;D
