broken bolts in head
Started by Captn. J, October 26, 2011, 02:44:48 AM
i have few broken bolts in my 460 head which i wanna get em out , anyone have a tool i can borrow , not sure what it  s called a reverse or extract?  something along those.
enough of the bolt left to weld a nut to the top?
maybe 3 of em but 4 or 5 of em flushed right off inside the head    F&^%
woody11769
think your talking about an easy out...........ive also seen guys used reverse drillbits and get them out..........good luck
Proud and Powerful
that sucks if they are loose in the hole a reverse drill bit is the trick if not drill and easy out but be careful to not break the easy out then it can get expensive good luck
Proud and Powerful
ohhh they are relatively cheap but try and get the better ones they are stronger and will last longer local auto parts stores and tool stores have them even sears sells sets
Drill n tap, only way to get the flush ones out without hassel
OR find a diff head ask danwheeler about that engine he has see if you can get a head off of it
is the head off the motor ,, is it exhaust manifold bolts ,,if so bring it to me  ++peace
if ya still need help on it i've got some tools that are good for that kinda stuff
bud
i have a nice tap and die set  that has alot of easy outs in it let me know if you need to use it
