oil pressure issues
Started by Kyle, January 15, 2012, 12:08:05 AM
Squirell
Sounds like a excuse to get out of warranty work
Quote from: Squirell on January 30, 2012, 10:11:54 PM
could be, but i just want it to get done. its there, they got it apart. if i go and take it to some other place ill still get charged for the same work
Yup, kinda sounds like that, I hope that aint true. Ive seen alot of things get covered up and called somethin else in my days. I could make a list of Dealer Garage rip-offs that would make your hair stand on end, done seen a bunch of them. Come in for an oil change n buy a motor loll
Sometimes its better to stick with the devil you do know instead of the devil ya don't...
how many cans did you use on it? come on it is not paint.thank of this what happen when the old timming gear (nolyn gears and silcone) got into oil pump pick ups. but as long as you get it back and good to go that is the main thing for you.
got to talk to the engine builder this morning. turns out all the other bearings werent nearly as bad as the one i pulled off. most of the main issues with the others were just the factory burrs on the bearings, and it was probably coolant that killed the one bearing. otherwise there wasnt any dirt issues underneat the bearings when i assembled them. nothin nessesarily wrong from me assembling it tho which is the good thing
