Drive By Wire
Started by Boggerram87, September 21, 2012, 03:32:30 AM
Boggerram87
The New Engine In The Mud Truck Is A 8.1 That Is Set Up With Drive By Wire, I Got Everything I Need Other Then The Gas Pedal Assembly, I Have The Chance To Get A Cheap One Off A 6.0....Anyone Know If Its The Two Are The Same?
lilred
Assuming yes. Call a part store or dealer and compare part numbers
I would think so. As long as the years are the same, it's just a resistor panel that measures where the throttle is placed, and tells the computer to open the throttle plate that same amount accordingly.
Boggerram87
Good Deal, Thank Ya Fellas
