trans cooler
Started by xjs3667, September 16, 2012, 05:15:10 PM
Idk if this has been covered yet or discussed but the thought crossed my mind....... Could I use a ac condenser for a trans cooler or a oil cooler?   I know they can handle the pressure but I mean there just as big as a radiator so I'm sure if it is possible it would do one hell of a job keeping the trans fluid or oil temps down??
Idk if it would flow enough, the internal passages may be too small, thats my only thought since freon is a gas
Thumper
I have one in each of the trucks, just use the bigger size tube. works great
THE D&D CREW
You can get a pretty large tranny cooler from summit (20x10x1.25)
Or something really close to that for $85
Quote from: Jthomas on September 16, 2012, 09:27:26 PM
I know..... but i just happen to have a real big ac condenser layin around loll
Yea I know, just incase it doesn't work.  I was just sayin. Lol
Quote from: Jthomas on September 17, 2012, 01:22:26 AM
gotcha.... I do have a few of the smaller trans coolers layin around too, but I have never noticed a huge difference in temps only around 5- 10 deg.   I like using those coolers for the power steering pump cooler, some say it is quite unnecessary to use em on a stock power steering pump setup but I have never had a pump go bad by using one with it.....
