2.5 ton gmc tcase question on shift patterns
Started by snocross2xtremes, September 25, 2012, 02:26:40 AM
snocross2xtremes
just picked up a truck that is running the stock 2.5 ton case. what is the shift pattern with the two rods? i can only seem to find high rang and netural..
94 yj Magnum 360 EFI,727,208, 1 tons front and rear and some 42's
99 dodge 1500 on 1 tons and 38.5s
www.unlimitedoffroad.com
page69
gm made three different t cases one hade high and low that was for the automatic trans and the one u have is for a stick trans it needs another t case in between to have a low ranger. but u also have a extra in your case . when u put ur truck in reverse u can pull the rod all the way out and u have 4x4 in reverse the other case does not .and the other case is smaller and has high ,low and reverse 4x4 and it also has almost a 3:1 low range.i have that case its nice .my brother in law has the other high low case and its way heavyer but still works good.the case number i have is a gm2
snocross2xtremes
Well i pick up another case and it seems to be 2 wheel or low? And the fronts always spinning?
page69
does the case have numbers on it if so what are they
snocross2xtremes
the first pic is the case that has low range. the second pics is the case that came out of the truck. also the case with high range only seem to have allo way bigger splines that the yokes slide on to.
page69
ill see if i can find the info and the website that explains the cases and sent it to u
snocross2xtremes
