removing paint
Started by dirty1ton, February 24, 2013, 06:44:25 PM
dirty1ton
any ideas on how to remove spray paint from aluminum rims. I have stock chevy rims and trying to find a way to take the paint off without wrecking the finish on the rims.
rollin_coal08
Find somebody with a heated powerwasher n turn it all the way up, will peel spraypant off anything
drogers
i know brake  fluid will peel paint if it is on the paint long enuf . idk if it would hurt the rim tho
gmc all the way
Quote from: drogers on February 25, 2013, 05:06:00 AM
it will take the paint off, but it might take off the alum. rims clear coat also..........might have to reseal them......probably wouldnt be a bad idea anyway to clean them up, then reseal them with clear coat once you get the paint off them.
Merc09
