coilover spring rates
Started by BlueChevy07, March 03, 2013, 02:59:43 AM
BlueChevy07
well building a new truck with coilovers all the way around got the rear weight down but don't know were to start on the front. Ive got 18 inch FOA coilovers the tuck is going to be lite its full tube chassi and body gutted. Ill be running a 496 big block chevy with aluminum heads. Any ideas on what rate springs ill need in the front any info will help the springs are a little pricey so don't want to order the wrong ones
4-play
you need unsprung weights of each side.
their are spring rate calcs online once you get the weights
there's a guy that's over here that told me he's weigh my jeep if I needed it for cheap. That would be your best bet get it built then get it weighed then you can figure it out better
BlueChevy07
cool that would be nice it should be lite not cutting any corners on this one
You could call bigshocks, the guys great. He could help you more directly, and all of your questions would be answerd.
But you still have to know the unsprung weight
yukonjake
Yes sir i have called him myself a few times for info jarods a nice guy he'll help ya out im sure
