gm 4l60e problem
Started by hrspwrjunkie355, February 13, 2013, 03:27:55 AM
hrspwrjunkie355
ok i have a 94 chevy 1/2 ton two wheel drive .  I hit a deer one morning and now i dont have 3rd gear or overdrive.  if i put the shifter in overdrive or 3rd it goes into 2nd gear.  if i pull it into low and shift it manually it will go to 2nd but stays there when you shift to 3rd or over drive.  i have replaced the speed sensor, checked linkage, wires was wondering if it could be the solonoid any help would be nice thanks
NO LITTLE BLUE BOTTLE
              ALL BALLS AND THROTTLE
Merc09
Did you check for a fluid leak?
hrspwrjunkie355
it dont leak i have put close to a thousand miles on it manually shifting 1st to second and drive 45 to 50 keppin it about 2000 to 2500 rpm gets about 5miles a gallon like that though
afoxrider169
I would say its probably shift cylinoids
73chevytruck
Is your check engine light on. Had a 94suburban I was working on that was doing that. Replaced the trans for the guy and it still was doing it. Pulled the codes. Needed a tps I believe replaced that and the trans went back to having 3rd and overdrive
hrspwrjunkie355
i have replaced the speed sensor but not the throttle position sensor
DirtyChevy
FRIENDS: will talk p00 to the person who talks p00 about you.
REDNECKS: Will knock them the f#$% out
chevv ==rocks chevv     REAL men wear bowties
Brook Chadwell is MY baby
buddman (AKA Mick)
Any codes? That wil tel u a lot.
86 Blazer on 38's, 355
