ID Ford Dana T-case
Started by Bo Duke, August 19, 2013, 06:23:40 PM
Bo Duke
I'm picking up an 87 ranger on a 70's bronco frame. I know its got a Dana 20 case but there at two types. Anyone tell me how to ID em? I need to know so I can order a twin stick set up.
Thanks
Should GOOGLE 66-77 Broncos, and see when those TWO different Dana 20's were used.
What exactly is "different" about these TWO different types of Dana 20's?
Bo Duke
The shifters are different as far as I know. Just got the truck home I'll crawl under it and get pics later.
fordrunner
There's a straight pull then a j shift style the j shift pulls all the way back then hooks right and up is there a shift knob on it if there is post a pic I could tell you
#5
Quote from: fordrunner on August 20, 2013, 05:22:19 AM
Keeping in mind that his truck was built using other drivetrain parts, I'll add that I have never seen the (  J-shift ) Dana 20 used in ANY factory Ford built product.  That was only used in Jeeps and some Chevy 69-72 / 73-74 Chevy 4x4s.
If you have the J-shift, there will be a "pivot box" that must be kept greased for the shift lever. Pretty sure you can't twin stick a J-shift dana 20.
Bo Duke
I'll be home in a lil while and get you guys a pic.
fordrunner
#7
Quote from: 7387chevynut on August 20, 2013, 07:12:55 PM
my 73 bronco had a j shift in and it was a pain in the ass
http://broncograveyard.com/bronco/i-11570-j-shifter-twin-stick.html
Quote from: fordrunner on August 21, 2013, 04:37:46 AM
Thank you for the clarification FordRunner,  I didn't think Ford used that style of shift pattern on their Dana 20's.   I've seen it on 70's full size Jeeps and on 69-74 Chevys, and have one from a 72 Chevy blazer.
I wasn't aware that a twin stick was made for them, they have a real funky shifter/pivot box, or at least my Chevy version does  as its part of the T-case adaptor assembly.
fordrunner
The eb 's are a little weird when it comes to most there parts. There's 3 different rear axles and don't get factory disk brakes till 76 there are a lot of bronco only wierd parts
tjbogger
Early broncos had the straight shifter and older bronco had the j shifter . had a 66 bronco with straight shifter 66 and put in a c-5 auto came with a j-shifter out of a 75 bronco . hated it never could get it back into 2wd after four wheeling .shifter was bad I guess .but read a little bit up on it and it said they had always had problems going back into 2wd with auto trans ..
  Jeep has a dana 20 to but different animal . They will not interchange .
tjbogger
If your going to build the motor up don't use an c-4 , they like to blow up every time you get on it .
To build up any horse power pick up an c-6 with an 205 transfer case out of and pickup and have it built to your engine rear end gears ,the cam and converter  . they have two types of c-6 one for small block and one from big block .and if you pick one up from and 78 or 79 bronco be careful and make sure it for a small block 351 w and not an 351 m .
