14 bolt leaf spring perch removal
Started by bignastys10, October 06, 2013, 07:43:59 PM
bignastys10
removing my leaf spring perches just wondering if there is a easy way? or if it is just a easy job maybe i am over thinking it. worried about cutting into the tube..
Use a grinder and cut the weld, you will see the seam start to be visible between the perch and the tube, then just knock the perch off with a hammer... It's easy just more time consuming then anything, unless you go crazy you won't hurt the axle tube
If you cut the tube, weld it back up. It's only metal.
bignastys10
yea thats true. like i said i might be looking to much into it.. lol thanks for the info..
bignastys10
got them removed easier than i thought.. now onto the front d60
