motor build
Started by d.a.m, October 21, 2013, 05:40:04 PM
d.a.m
I got a 350 60 over it in a 94 chevy 1500 on 35... all of it new not happy with
Out come .... I'd like to be passing 400 plus howerspower will be using for mud and
Street ... what cam, heads, and carb would u use
73chevytruck
I got a .60 over 350 in my truck to. .510 lift comp cam. 280 duration. 2.02/1.60 edelbrock aluminum heads. 1.5 roller tip rockers .Rpm dual plane intake and 750 edelbrock carb and it runs great. 3500 stall as well.
http://static.photobucket.com/player.swf?file=http://vid1001.photobucket.com/albums/af138/73chevytruck/VID_20120911_161923.mp4
Merc09
What intake do you currently have? Carbed?
d.a.m
600 holley and no sure on intake eldbreck .it a freash rebuilt just not happy with it
fordrunner
#4
400+ HP aint out of the realm of possibility hut a little more info on your bottom end would help. Flat top pistons, dished, dome? Stock bolts in the bottom end or is it studded? And what gears are you running that will make a diffence
come buy my 400 hp motor? lol  buy some big heads and a mild .500+ lift cam  run around 10 to 1 compression  and a 750cfm holley  should make good power.. for heads Id look at something like dart or another after market brands
d.a.m
It got .60 flat top pistom 204/214 @05.
420/443 w1.5 rocker
  194cc heads
Eldebrock perfomes intake
Mellung rocker arm kit rods lifter
Quote from: d.a.m on October 23, 2013, 06:35:12 PM
420/443 w1.5 rocker
  194cc heads
get a bigger cam and better heads
d.a.m
What size cam should I go with got 202 heads
Id shoot for at least a .500 lift cam and if your heads are 2,02 id have them ported
Yea your can is definitely holding you back....as betterbeaters said get heads ported, measure max valve spring compression so they don't bind, but I'd go with around a .500-.510 lift can, you'll notice the difference immediately :-)
fordrunner
your cam sucks lol low rpm rv cam. are your heads just a stock camel backs?
d.a.m
what making model  model cam would be a good one
