454 please delete
Started by Bowtie972, December 12, 2013, 11:33:41 PM
1976 2 bolt block .060" over Sealed Power Hyperutectic pistons 9.0:1
1973 049' Oval port heads fitted with larger valves, 2.19" Intake and 1.88" exhaust valves, No port work
Harland Sharp roller rocker arms
Comp Cams Magnum .550"/.550" Lift 244/244 duration cam
Summit Stage 2 intake
Moroso 8 qt deep oil pan
balancer
starter
flex plate
1 season on new Holley 950 Ultra HP carb
MSD ignition
$2,500   obo
i can start it for you, so you can hear it run.  Located in Vassar, MI  989-233-5861 Tim
Quote from: marshall on December 16, 2013, 12:21:17 PM
Separate the carb?
If the motor sells without it i will.
 bumpp  Runs on pump gas, I have a milder Comp  cam that can go with it, would even work as a stout motor for a tow rig...  Tons of torque..
$2,500.  Time to move it
Please Delete  keeping it
