6-22-08 aftermath of the mounds(updated 6/29/08)
Started by Crazymays77, June 23, 2008, 01:13:16 AM
Well I had a good day at the mounds until I had to be jump started every 2 mins. then I think the starter went bad. Then the kicker I was towing it home with the tow bar and the rearend locked up. So I had to go home and get the trailer and load it up and go home. I will tear the rearend apart and see what happened and update you all and I will post pics if I can. I took my tracker and jumped the deep end of lake michigan. everyone said it was awesome but I didnt get pics or vid. that sucks. I even went through keago harbor.
blasterguy911
1972 bronco
update on the tracker. I drained the rearend and it was mostly water. I just changed that a week ago. so i have a bad seal some where. then when i did drain it the plug had a piece of a gear on it. here are a couple pics. I will have to take the third member out and see where in came from and get the rest of it out and get some seals replaced along with the gears.....
yeah i need a a third member for it have one bd???? ha ha
i have a few front pinions, nothing for rear axel tho
that sucks I will have to try to get a parts tracker soon.....
yeah on my way home it locked up and i dropped it there and went home and got a trailer and hauled it home.
barnums have lots of rears, i bought all the fronts   at 25 each
mudboggincrazy
that  sucks  bout  the rear end  but your  jump into lake  michigan  was  bad @ss  so was  the  2  trips  threw  keago
well I will get to find out whats all broke in the rear end i spent today going thru the new one thats going in it. I also found out that my front t case seal leak and the front diff seal leak and the pinion bearing its bad. guess i'm gonna be putting some money it the tracker...
Well it looks like the pinion bearing got a little hot and burnt up and thats what locked up... here are some pics. as you can see there was some water in it. i got another rearend and took it apart and welded the spider gears up and took the old rear end out and now i have to get the rusted bolts out of the links so i can put it back together. damn rust. so i wont be playing anytime soon. plus the front pinion bearing is getting pretty bad gonna have to change that soon.
CRAZY MAN broncomudhead
loooks like it's been spining water for a while ?
HERES MUD IN YOUR EYE
yeah i drained it a few weeks ago and put new oil in it. and I went to the mounds two sundays and then it went out. the seals were bad...
Bo Duke
im no master mechanic but that dose not look good....lol
