Anyone made a frame before?
Started by Eroq, July 24, 2008, 04:56:28 AM
blazentrout
yep,for my '78 door dragger suburban. truck is still a work in progress. what is the question?
wildtime has!!!! and it rocks ask him he the man!!!
I am gunna be starting one very soon gunna put my 70.5 camaro on 42sor bigger with my 383!
blasterguy911
awsome sounds cool better beaters
1972 bronco
i'm considering doing it for my new s10 body.. old frame is getting past its time... plus it would make it alot easier for 4link ;)
I have that reboxed CJ frame I'd sell ya
just needs a couple of finish welds and it's ready to go ^
blazentrout
i have a couple of minutes to type, so i'll post what i learned.  buy the book chasse eng by herb adams and read it a couple of times. take a look around and see what type of frame you like/part of, take pics and mesurements, notes(a pic with the tape in it is great or some thing to use as a scale cough "beer can" cough).see if the owner or builder is around and ask questions with one of them being if he/she had to do it again what advice would they give.
material size and type. good ? ask 10 people and you will get 12 answers. i noticed a leming affect on this from the mini trucking world and it is not alwas the best thing. ex 3x3 box tube is better than 2x3 for vertical bending ,reality they both have the same height verticaly so they are just about the same. triangulation is your friend.if you dont have a desent welder(not a 110) buy one.
a couple of tricks,weld the top and sides and then tip it up to get to the bottem welds(saves burns) ;D. if you can leave the frame in the same spot from start to finish, it saves a lot of levaling time. get a second hand when you square and level for the first time.try to jig it up at a good working hieght, your back will thank you.jason at suicidedoors.com has a lot of brackets and parts cheap. time to go back to work.
Fraser
the dokes built a new frame for grumpy, had a it up on a table in their barn when i saw it. good working height, level, etc. is the most important
have not tryed,  but i don't think it would be that hard
Econo-box from Hell
I'm tired of rust so I am building my next frame out of wood.
==nw geoo ==wn
Squirell
