Removing over spray
Started by Groundhawger, July 29, 2008, 05:45:09 PM
Groundhawger
hey  GotMud? do u guys have any suggestions for a way of getting over spray off paint? thanks
Bo Duke
if it's new overspray on old paint you can use thinner but don't do it if it's on fresh paint ;) otherwise if it's on fresh paint you'll have to sand and buff ==doh
stroker ace
go to a autopaint store...  buy some finish enhancer and a clay bar for overspray on the body panels... spray the finish enhancer generously on the area with the overspray and work it in with the clay bar just as simple as that you'll get rid of your overspray there... however if you have overspray on the glass i used to scrape it off with a straight razor until a painter showed me a trick with just using glass cleaner and steel wool which is a lot easier just spray glass cleaner generously on the overspray area and just go over it with the steel wool and it will work on both fresh and old paint
LIFT IT FAT CHIX CAN'T JUMP
