how much for this axle
Started by chevystudz7105, September 02, 2008, 11:47:58 PM
chevystudz7105
i got a 14 bolt semi floater in my 82 chevy muddin truck right now that im going to pull out and put a 14 bolt ff in, and iwas just wondering  what i might beable to get for this axle.  as far as i know it has 4.10 gears.  but i wont know forsure until i pull the cover.  but what does everyone think i can get for this?
You can buy a Full Float 14 bolt for around 100.00 depending on what axle ratio it has, and or if it has a posi............when you get to 4.56 with a posi........your looking at 200/250.
Open Semi float 14 bolt..........probably 75.00. Most hard core boggers want strong axles..........so the lighter axles get swapped out.
Your semi float would be a good axle for a 4 wheeler who is looking to upgrade from a 10 bolt or 12 bolt rear axle.
MAYBE .10 A POUND AT SCRAP               MUST WONT WASTE TIME WITH A  SF  JUST MY 2CENTS
chevystudz7105
yea i understand most people will get rid of the semi floater  and go ateast the ff   thats what im doing.  just thought id see what i might beable toget for it seeing as nothing on the semi floater is of any use to me when i get the other axle in the truck.
chevystudz7105
8 lug.   interested in it?    i havent posted it in the forsale section yet but if someone sees this and is interested it  pm me.  at the moment it is still in the truck but if someone  is serious about it i will pull it out as soon as i can for them.
