transfer case question
Started by chevystudz7105, October 30, 2008, 12:51:22 AM
chevystudz7105
i just came across a deal on a driverside drop 241 transfer case out of a 97 or 98 3/4 ton truck.  now my 82 chevy has a passenger side drop 208 t case.  would i beable to take the guts out of that 241 and put them in my 208 or no?  i dont know the gear ratio difference between the 208 and the 241 but i was told that a 241 t case would be better in my truck.  but they are a lil harder to find.  so i was wondering if i can swap out the guts?  if so  is it worth it to do it  or wont i notice much of a difference?
thanks for any help
chevystudz7105
Even though I'm a firm believer in that the (NP241 and Np208) are basically the same (internally) I know that they are not.....................so no...........I wouldnt attempt trying to swap parts from 1 T-case to another.
The Np208 has a 2.62 low range..........and the Np241 has a 2.72 low range............so your not gaining a whole alot.
The NP241 T-case that you are looking for......................can be found in any 1989-1991 K5 blazer and fullsize suburban and they are passenger side drop..........just make sure its 27 spline for 700r4/ and not 32 spline 400 turbo (400 turbo optional in 3/4 ton suburbans)
But since the passenger side drop Np241 was only offered (3 years) they tend to be harder to find than the more common driverside IFS drop 241's.
chevystudz7105
yea i know i need the passenger side drop and that the 241 is a lil harder to find but i thought maybe i could swap out the parts.  i figured  everything was the same  just geared a lil diff on the inside.  but since they are that close i wont bother.
just thought id check  cuz i could pick up that driverside drop 241 cheap.  guess i could still pick it up and keep it as a spare for my 91.
