brake light/turnsignal/cruise problems
Started by Groundhawger, January 13, 2009, 04:18:03 PM
Groundhawger
the wife has an 01 chevy lumina. ever sence i bought it, the brake lights work when they want to, and the turn signals and cruise never work. im thinking its something with the steering column but not sure. Any suggestions will help. thanks
In my '96 K1500 the multi function switch had some wires melt and short together. ie. when I would turn the truck off with my foot on the brake, truck would keep running til I lifted my foot off the brake. All sorts of weird stuff. Check the wires running to and from it for any melts or signs of heat.
i had a 90 cavalier, cruise wouldnt work, i changed computer in it & got my cruise back ==dunno check fuses too.
Marion3
Sounds like a multifunction switch.
I had that happen with wipers and brake lights on my cherokee
Groundhawger
fuses are all good. Depending on the cost, im gonna try that multifunction switch and see what that does.
Groundhawger
where is the multifunction switch on that car?
mr. goodwrench
its behind the steering wheel, comes with the t/s switch hazard and the cruise switch, that was a common problem on those cars. Last check they were dealer only part and they were quite pricey.
Groundhawger
so i take the steering wheel off and its right there? what if i switch the steering column, would that work?
mr. goodwrench
should but a lot more work. Just remove the wheel once you have the new part pretty easy to see how they bolt in, not hard to do at all, should take 30 min max.
