Add-A-Leafs
Started by TBigLug, January 16, 2009, 11:45:04 PM
Does anybody use them? Reccomend them?
I can get a set for my '85 for ~$60 for the rear and $70 for the front new. I'll be doing a little towing with it when I'm done so the stiffer spring rate doesn't bother me.
mudweiser
Had them in my 86 1/2 ton the ride is very stiff I wouldnt put them in again
I'll SINK MINE TO THE FLOOR BOARDS CAUSE I GOT FRIENDS WITH TRACTORS
I don't think I'll mind the stiff ride too bad. Did they help when you were pulling trailers? I'd like to use it to pull my stock trailer and draft horses when I'm not playing.
mudweiser
Yes it helped it was just the front add a leafs were way to stiff
Disturbed Sledneck
I've used them in the past on an F-350, front and rear.  Rear is fine, helps with payload and towing and ride isn't all that bad.  Though, I will never do a front add-a-leaf again.  Ride was way too stiff.
camok10
 maybe you could find some used 6" springs for the front and do aal's in the rear
84 c10 project
82 c10 beater diesel
I thought about that. But, problem is finding a set of 6" springs for $100.
