Trans help
Started by mudslayer2008, February 01, 2009, 02:31:17 AM
mudslayer2008
I was in the middle of hooking up my floor shifter I got and I broke the nut and the threads off the gear selector that hold the bracket. My question is how hard is it to replace this part in the trans ??? it is a 400 turbo 4x4 trans out of a 79 pickup
                                         Thanks  Gary
mr. goodwrench
I have had that happen and I just put the lever on and added a little tack weld to hole it and never looked back, sucks when you go to drop trans as you have to grind the weld. In order to repair the shift shaft you have to drop trans pan unhook the manual shift valve and then unscrew the nut that holds the "rooster comb" on, then pull the shaft out might as well put a new seal in when you pull it. if it were me I would just weld it.
nope
its not to bad to replace that rod just a clip and another bolt on the inside
mudslayer2008
Thanks for the reply I may just weld it for now
