new rims and tires on the camaro
Started by slymer, August 31, 2010, 08:22:22 PM
15x4's in front with 165/80-15 Kuhmo power stars. 15x8's in rear with 275/60-15 Nitto nt555r extreme drag radials. I bought the rear rims with 5.5 backspacing so they would tuck in good with no outer fender rub. I ended up doing a little inner fender work (BFH) to get them to clear. You can't notice it with a fresh coat of undercoating and the tire in the way. It almost saddened me to beat on such a solid car but thats the size I wanted. I made them fit with no rubbing. Any wider and it would have to be tubbed and I don't want to do that. Next up subframe connectors. More
http://s300.photobucket.com/albums/nn14/slymersami/camaro%20after%20new%20shoes/
Looks Bitchin!!!!! Same size i got on mine!
7d9_z28
Pulled off the edelbrock carb and replaced it with a holley 750 with a proform main body and billet base plate. Should wake it up more.
cnoswalt78
hey I have a red 85 z28 350 maken 500 hp ( thinken of putin it in the truck) but its 8500 rpms (i dont no yet if i likethat idea) that s it leanen on the tire.
Quote from: cnoswalt78 on September 29, 2010, 12:39:12 AM
Thats about the same amount of hp I'm pushin.
liftedboomns10
