97 sas one ton
Started by Red97, September 12, 2011, 10:31:39 PM
Red97
Here is a short build thread of my 97 sas.
started life with a 6" fabtech i got tired of it so i swaped ome one tons under it
52" chevy springs for the front. i added 2 leafs to the pack total of 7. home made shackles for the front. a little long for mock up purposes
rear shackle hangers are off the front of the f350 donor truck
boxed a small part of the frame to help hold the shackle
rear spring perches and a dropped pitman arm for the crossover steering.
home made hi steer arm for cross over steering
disk brake parts for the rear axle
pic of the donor truck
dropping the old lift out.
tacked the shackle hanger in place for mock up
pic of how it sits on some bald 33's
custom front crossmember and spring mounts.
added some gussets
pic of the spring hanger all welded
boxed the frame to make it easier to weld the shock towers
the shock tower welded on.
pic of the crossover. 1.75 od .5 wall. tube
pic of the rear shackle flip all home made
pics of it all done with 33's
made some hd side steps 2x2 1/4" wall
welded some gussets to the frame
bent a hoop up and welded it to the step. painted it with wrinkle paint
pic of the bumper i made with a 2" stinger. it is 6" c channel with 1/4" dimond plate on the top
pic of the truck with 35/15.50/ 16.5 tsl.
let me know what you think.
also added 35spline outers and warn hubs.
home made hydrulic assist.
TOMAC
hell ya good work! how she handle on the road?
bigblue
any pics of the hydraulic assist
justin kopac
JcKinney
Red97
thanks. it handles great on the road. I will get some pics of the assist soon. as with the curent wheels and tires
JcKinney
If I do this to my yukon, I'll be callin you  :P
looks good! should be fun!
