motor idenification
Started by danwheeler660, February 26, 2011, 11:17:15 PM
danwheeler660
how do i find out what motor is in my bronco and what year it is from thanks for any help Dan
.1996 bronco 351 32.11.50 15
juggernaut
need the numbers off heads and block
danwheeler660
i found this number on the block in back i think it is    A36168    or  A83168
on a ford  count the  bolts on the valve covers.  ill find the page  that you can count the  blots on the valve cover and you will know what motor it is
http://www.fordcobraengines.com/engineid.asp
or this one
http://www.fordification.com/tech/engineIDtags.htm
here what i was looking for
The quickest way of differentiating between the different familys of Ford engines is to simply count the valve cover bolts.
2 bolts: 239/256/272/292/312  (produced from 1954 to 1964)
5 bolts: 332/352/360/361/390/391/406/410/427/428 (FE engine)
6 bolts: 221/260/289/302/351W
7 bolts: 429/460
8 bolts: 351C/351M/400
danwheeler660
how do i find out what the year is i think i need a new water pump but need to know what year the motor is
behind the  starter  is a casting #
C is for  60s
D is for  70s
E is for 80s
F is for 90s
it will be like    D7###   this is a 77
a D9  id a  79
hope this helps
danwheeler660
ok i will look tommrow it is to dark out now thank you
Quote from: Ranger Dave on March 01, 2011, 12:10:17 AM
C is for  60s
D is for  70s
E is for 80s
F is for 90s
a D9  id a  79
hope this helps
this is a 79 block
D9VE-A2B
danwheeler660
well me and the wife spent about 20 mins under the truck today and we still can't find the casting numders we look on both sieds of the block down botoom and i even looked at the back of the heads and we are just not seeing them we looked all around the starter we are lost,,
Quote from: Ranger Dave on March 01, 2011, 12:25:30 AM
this is a 79 block
D9VE-A2B
danwheeler660
ok i took out mt stater and found the numbers i have E0AE/D3C so i hAVE a 1980 block thanks for all the help
