rod question..
Started by Squirell, September 14, 2011, 12:23:26 AM
Squirell
say your building a 383......does the cubic inch change with rod length or just the placement in the piston.
thanks. ex- 5.7 or 6.0 or 6.125 rod. i know changin the stroke of the crank changes the displacement. just wondered about rod length.
I dont think so cause no matter how long the rod is its only gonna go as far up n down as the crank will let it in the cylinder. Hopefully you dont laugh as much reading that as I did typing it.
Squirell
yea kinda what i thought to....just thought i would ask someone who actually knows, but thanks
hot rod heep
no rod lingth  dos not change  the displicement    it only changes the pin plicement in the piston   [ longer rod  higher in the piston ]
03 jeep liberty  on k5 frame
Dana 60/14  410 gears
44 boggers
BBC th400/208
Quote from: hot rod heep on September 14, 2011, 01:34:00 AM
x2
changes the compression height, which is the placement of the rod in the piston ++peace
http://www.lunatipower.com/Tech/Pistons/CompressionHeight.aspx
bigmud44
does not change displacement but does change rod to stroke ratio which can make HUGE difference in some engines
it doesn't change displacement, but the longer rods with the longer strokes in the small blocks causes problems with your rings, i would NOT recomend going longer than a 5.7 inch rod with more than a 3.48 inch stroke, unless you like your wrist pins scratching at the back side of your oil ring pack......
