Brake Rotor swap 2wd C1500 88-98
Started by Cannaert, July 25, 2011, 08:06:18 PM
Ok Here is what I am thinking of doing.  I have my 95 2wd 1500 Ext Cab SB.  I was looking into doing the Heavy Half to 2 wd 6 lug swap on it.
I just wondered if any ones else has seen it done or may have a Old rotor from one to see if I can do it with out swapping out Spindles as well.
I have my Reasons for doing this to the truck.
91 k1500
just buy the rotors for a 2wd 2500 chevy pickup, you have to get the ones that are under 7200lb gvw to get the 6lug... the other ones are 8 lug. It is a direct swap bearings and all....  doing this on my 2wd c1500 so I can run a set of 20" 6lug wheels.....
Quote from: 91 k1500 on August 02, 2011, 04:50:12 AM
I got the same Idea here as well. 6 lug rims a much easier to find then the damn 5 on 5 rims.
