ford transfercase
Started by danwheeler660, August 25, 2011, 01:49:55 PM
danwheeler660
looks like im picking up a 460 this week end.And i know i have to get a big block c 6 transmission becuse my c 6 on my 302 would bolt up but will my tranfercase from my c 6 now bolt to the transfer case of the big block c 6? thank for any help
.1996 bronco 351 32.11.50 15
wayne w
it should mine came off a sbf and bloted on a bbf
danwheeler660
wayne w
just make the splines on the two tranys are the same
MUD HUNTER
The only difference is the bell housing bolt pattern... Everything on the back should be a direct bolt up. But keep in mind, the C6 does come with one of two different out-put shaft lengths. If the shaft is the same, you're golden.  ++peace
