toploader help
Started by Blake Scheuneman, August 16, 2011, 05:32:39 AM
Blake Scheuneman
My 5 speed from a 89 cummins. It was not wantin to go into creeper (1st) and I pushed pretty hard on it. Well it went into creeper and is stuck. The shifter moves around like it came unhooked. Took the boot off and everythings fine going into the trans. Feels like and sounds like a broken spring? Any ideas here
chevv ==dew alll
rangerwheelinmike
if you pushed on it hard you could have bent the shift forks?
Blake Scheuneman
It won't even try to go into another gear
chevv ==dew alll
give my dad a call 9897290700 ask for rob
MUD HUNTER
Sounds like you may have forced the shift fork over the gear... when that happens, the stick feels like its in neutral, but it will actually be stuck in a gear. Pull the top cover off the trans... usually pretty easy to get back in order. ++peace
Blake Scheuneman
chevv ==dew alll
