JEEP HELP - RUNNING HORRIBLE
Started by t_ank5, August 17, 2011, 10:34:17 AM
t_ank5
Quote from: my broke ass ford!! on August 17, 2011, 11:21:05 PM
its passenger side under the hood where all the links are at that i found and when i replaced the one i found more that where getting corroded (sorry for the bad spelling)
you have a pic of this
2004 silverado 1500 dd
2001 silverado 2500 HD wt
1996 s10 blazer summer dd/toy
1984 k5 blazer toy
t_ank5
put new plugs in and running good so far
1984 k5 blazer toy
also try the ballast resistor, or change the map sensor, crap which does remind me i gotta do the same thing because mine does that also an 88 xj, but i did find that when i put the tranny into power mode it ran somewhat better.  also check all the vacuum lines, because those mopars are nothing but a big vacuum cleaner. loll
t_ank5
NEW PROBLEM
FUEL PUMP STUCK ON AND COOLING FAN STUCK ON
1984 k5 blazer toy
rangerwheelinmike
wow you must have a big electrical problem ???
t_ank5
I'm thinking so. I cycle my key forward and the fan n pump stay on I've rotated relays nothing checked fuses nothing. The gas gauge volt gauge and temp gauge aren't working =\?
1984 k5 blazer toy
t_ank5
well i unplugged all plugs and it did the trick idk whats going on
1984 k5 blazer toy
Sounds like this truck has been under water. Unplug every single connector on it, spray real heavy with electrical contact cleaner, blow dry, and then WD-40 them all, that should help alot. Undo all grounds and clean them up real good, too. ;D
rangerwheelinmike
Quote from: old school truck dude on August 19, 2011, 01:37:26 AM
x2
t_ank5
Well I think its all figured out now. crossed my fingers! But its all good and drove it all over this evening. so we will see.
1984 k5 blazer toy
Clear the codes... wait for them to pop back up and see what they are.
t_ank5
That's the plan she running goof tho
1984 k5 blazer toy
