need hydro steering help
Started by Truckmonkey, September 01, 2011, 09:03:09 PM
Truckmonkey
 ==fo ==fo
'the DON'
2 hoses to the pump 2 to the ram thats it
==wgm
There should be 4 fitting on the valve. 1 is for the pump, 1 for the return to the pump, the last two r for the ram one us for right and other is for left. Mine is marked P, T, L, R. Hope that helps. Just make sure u jack the front up and fill the pump then cycle the steering to get the air out could burn something in the system up.
you will have to take that line to a shop that makes hydro lines and have them put the right end to hook to the orbital valve.
'the DON'
take the lines and fittings to fairhaven auto parts in mt morris they can help
==wgm
'the DON'
==wgm
I have weiss equipment in frankenmuth do mine
randycrane79
d&d truck n trailer here in owosso could make it for ya
Rollover Herb
==ogm
Quote from: truckmonkey on September 01, 2011, 10:02:28 PM
I got the two hoses to the ram and the return (tank) line figured out. Just having trouble figuring out how to adapt the presure line from the pump to the orbital valve. The pump uses automotive fittings and the orbital uses hydraulic fitting.
i used some hyd to flare fittings for mine  got em at the auto parts store and  they made me a couple lines also
'the DON'
==wgm
