relocating rad to the bed
Started by jeepingchris, September 27, 2011, 09:29:26 PM
jeepingchris
ok, i know there are alot of you that have done this so i need your help..... i want to move my radiator to the bed. what do i use for pipe? plasic or metal? water or antifreeze??? size, where to run it...all your input will help me get it back there... GotMud?      oh and if you have pics to give me ideas that would be cool too
If the muds not flying.....push a little harder on the pedal.
exhaust pipe and antifreeze is all i know lol.
Quote from: lilred on September 27, 2011, 09:47:58 PM
yep but I use water till it gets cold out...
Heater hose antifreeze/water, are u gunna run two radiators or one
First thing you need to do is check with the wife..
mine was pissed!!  ==pissed  said it hurt her back..  ;D
Quote from: Hammerlane on September 28, 2011, 03:54:07 PM
i was gonna make a similiar comment but ya beat me to it ;)
I think theres pics of my rad lines in my project page
1.5" exhaust tubing with radiator hoses to connect to the engine and to the radiator, I run typical antifreeze mix, electric fans with shroud...its not too bad to do, just make sure when you fill it, you do it systematically, pm me when you get to that point, mine worked on the first try with the above configuration.
woody11769
Quote from: ProGrade on September 29, 2011, 04:21:56 AM
im glad it worked
