double cardian driveshafts
Started by Captn. J, October 18, 2011, 04:36:35 PM
mine need to have u joints replaced but shop wants close to 200    i know i need a press but dont have one  and dont want torch it to p00... any tips or whatever to have it done or if someone had it done before can help?
all i can see they factory oem   where i have to torch the plastic thing out ... i think it ll be a cleaner thing to do with a press  but i ll see if anyone got a good press
I've heard of guys using ball joint tool to do this
randycrane79
ive done it with ba press and a balljoint tool only reason for torch is to heat the original cups loose with fiber inside of the driveshafts and ive used a socket inside a vise they all work about the same for me i even used a air hammer and a socket works good to but noise.......i wouldnt pay for anyone to do mine unless dont have these tools
i have all ways use the torch on them. heat them up come apart real easy.
You can do it with a lil heat & a hammer n socket. How soon do you need it done? I have access to a shop press if you cant gettem out.
Sending a PM
rangerwheelinmike
gota heat them up so the glue melts
RedneckMudder
yea when we did mine we torched them to get all that plastic p00 out and then used one of them ujoint/ball joint tools from harbor freight to press them out
Truck-$1200
Lift, Tires, Axles-$1000
Misc. Nuts & Bolts-$650
28 Cases Of Beer-$280
