vortec specs
Started by jays85, November 13, 2011, 07:48:56 AM
jays85
what is the specs on the head and intake the intake i have the good felpro gasket steel with rubber and some people are telling me 11ft lbs but then some say more because of the thick gasket ??? thanks
gator82
#1
THIS IS WHAT I FOUND HOPE IT HELPS:
FOR THE HEADS, TORQUE THE BOLTS THREE TIMES
1ST @ 25 LB/FT
2ND @ 45 LB/FT
3RD AND FINAL @ 65 LB/FT
FOR THE INTAKE:
Install the lower intake manifold bolts. Tighten the bolts in three steps:
Tighten
Tighten the bolts on the first sequence to 8 N·m (71 lb in).
Tighten the bolts on the second sequence to 12 N·m (106 lb in).
Tighten the bolts on the final sequence to 15 N·m (11 lb ft).
I WOULD PERSONALLY TORQUE THEM DOWN, WAIT A BIT AN RECHECK THEM AND RE-TORQUE IF NEEDED.
jays85
