lug bolt patter
Started by BLZNBIG, November 10, 2011, 12:04:08 AM
BLZNBIG
on dodge rims.. what is the big bolt size?? theres the 5 on 4.5 and i believe the other is 5 on 5 right?
cumminsmatt98
The 4wd is 5 on 5.5 same as older ford and old jeep. Not sure about the 2wd trucks tho.
84 and older 2wd has the 5x4.5 and so does the 82ish and older 4wd. everything newer from 85 and up has the 5x5.5 bp
85cHeavyMetalBogger
Quote from: 85cHeavyMetalBogger on November 15, 2011, 06:42:10 AM
8 lug?
8x6.5 all 8lug except the super dutys have the same bp. superduty has 8x170mm
