Chevy 358 TBI cam??
Started by OHEARN.2012, January 17, 2012, 05:04:20 AM
im currently building a motor for my pickup its a 358 sbc im keeping the tbi for fuel economy and becuz truck has 4l60e in it.  i want an rv cam because its a work truck plus i do some hauling. but unsure of what i was going to get??? i need something that "will not" screw up what the computers trying to do so someone help me out please
twofass4u
summitracing.com has a few comp. compatable cams. Or you could call comp cams tech line they'll hook you up!
engine builder told me to go with a stock tbi cam becuz he said he put a stockier cam in a newer computer controlled engine and it was messing up and leaned it out
You just gotta change the prom in the computer, no big deal. It has to match your cam, buy a cam with the prom chip as a set. ;D
where can i find them?? and how the heck do i change that?
Quote from: Disturban on December 21, 2010, 06:42:04 PM
When ya get it all together and if you cant get it running right the problem will probably be the gear drive messing with the knock sensor...just a FYI Public Service Announcement!
Also you will want an adjustable fuel pressure regulator!
Let me know if you run into problems I have a little experience with setting up TBI's...also what kind of transmission are you going to be using? It matters when it comes to what computer you are going to need...you just cant use any 350tbi computer.
Get with Brian at tbichips.com and tell him your combo and he will be able to tell you what computer you need and/or be able to burn a custom chip for you.
