fuel pump question
Started by Captn. J, March 28, 2012, 07:13:11 PM
 i have a edelbrock 1406    i read on the net   that it takes about 5.5 to 6 psi  , i m currently running a elec pump from autozone that says 5.5 to 9 psi   will i be ok?  is it a self regulates?
should be fine. i run one of those fuel pumps and a holley 600 cfm carb works great.
good deal then    one less thing for me to worry to get my truck done for bondy
Boggen Joe
Should be good. It's not the psi really, it's the volume a pump produces. An average only needs 6-7.5psi. A stock motor needs 30-40gpm. As motor gets bigger needs more gpm fead to it
