Power steering cooler and reservoir
Started by four_by_ken, August 05, 2012, 01:40:13 AM
So, I replaced the power steering pump in the Blazer... run it up the road and back down.  Gave it some RPMs.
Power steering fluid got HOT HOT HOT.  (Running full hydraulic)
So, I want to eliminate this problem.  I am going to add a reservoir and a cooler.  How have you guys set this up?
i put a cooler from a newer chevy truck onto mine and     a   hydroboost  pump and reservoir  dosent get hot at all  the cooler is about 3 x 12 inch long
hrspwrjunkie355
just run a tranny cooler in your low pressure side
NO LITTLE BLUE BOTTLE
              ALL BALLS AND THROTTLE
