Fuel pump ?
Started by Boggen Joe, August 09, 2012, 11:56:34 PM
Boggen Joe
Where do y'all run you elect fuel pumps? In cab, frame rail?
Here's the deal, I'm running the stock gas tank, I don't if I should mount the holly black on the frame or in the cab of my blazer bogger, I don't know if all the mud n water will hurt it?
Any input will help
mine s on the frame   easy ascess to it   and i bog hell outta it and water didnt hurt it
'the DON'
mine is in my toolbox in the bed . it stays clean and doesnt look like it came off a bogger
==wgm
Boggen Joe
I heard they have to be leave or below the tank?
Quote from: Boggen Joe on August 10, 2012, 12:38:39 AM
it's not a matter of life and death if you can't but remember electric pumps push better than they pull ;)  so if possible use gravity as your friend.
My holley red wouldnt work till i put it level with the bottom of the tank
557stroker
holley pumps r  gravity feed.(push)they r not to  pull fuel out of the tank or they will over heat and u will burn the pump up
they r not made to pull fuel out of the tank u will over heat pump
71 Highboy
Quote from: 557stroker on August 10, 2012, 11:33:16 AM
x2
TNT BOGGING
mine works fine  its a couple inches below the top of the tank if yer using the stock tank its got to draw the fuel out the top no matter where the pump is located  mine draws it from the top down a tube similar too a stock tank does  it makes some noise till the  fuel gets to it but dont get hot   i did have a issue with the  pump locking up doo to water gettin into the bottom bushing on the pump
Boggen Joe
Just don't put it IN the cab with you not a good idea to keep gas in the cab. I don't even keep the fuel pressure gauge in the cab.  Gas in the cab eliminates the reason for a firewall.
I have my black holly on the firewall under the hood. No problems, and it was used, came out if the boat. I just silicone the wires where they come out of the top to ensure nothing get in it. I do this with all my fuel pumps, and I actually notice a difference.
